RCU Forums - View Single Post - Fastest BRUSHED motor
Old 05-29-2004 | 11:07 AM
NYYSR
Default RE: Fastest BRUSHED motor
ORIGINAL: Intelligentsia
Well,
Mass produced what exactly do you mean by mass produced? You mean those mass Produced tuned 300 motors? Because you and I both know that those motors are not exactly "mass produced."
The 280 motor that I use is mass produced as is the 300. Like Grafix and others, I then modify these motors so they may yield their best results.
My comment regarding the 1/10 drivers was obviously pertaining to closed endbell 540 motors.
As far as replacing the brushes, this is a simple task. Purchase the brushes for $2.99 and solder the shunt on to the post. No more maintenance is necessary unless you always want to keep your motor in tip top shape.
One set of brushes will last as long or longer than a tuned 300. So really the maintenance does not even come close to the cost of replacing these motors after every 15-20 battery packs.
first off i never said their was NO drop of in power at all, you need 2 read what i said more clearly.
and i NEVER claim that the 300 motor will last longer so stop misquoting me.
nows where i point out where i question your truthfulness.
above you say i know that the 300 are not mass produced, when i FACT they are.
they are machine wound NOT hand wound and just cauzz they are later tuned doesnt change that fact.
then in your very next sentence you say that yours and the 300s ARE mass produced??
are you confused? i think you might me.
either that or your a flat out liar when you told everyone on here that your motor is CUSTOM BUILT HAND WOUND motor, when all it actually is is a tuned motor.
i didnt say these things YOU did.
you said your comment regarding the 1/10 drivers was obviously pertaining to closed endbell 540 motors.
well were not mind readers or an (Electrical Engineer ) as you pointed out here bro so i can only go by what YOU posted.
your quick 2 tell everyone what it cost for the brushes (2.99) but fail 2 say what your motor cost and what it cost 2 REBUILD it.
you also fail to tell everyone what you charge 2 rebuild it for them as this is not an easy task for the average joe.
i fully understand your trying 2 make a buck, but bashing and lying about the 300s 2 make that buck is just NOT cool.
im sure theirs not 1 person here that believes your 15-20 bat life span, how could they that claim is a joke that anyone with a 300 and has gone well over that # knows.
i wouldnt by a thing from someone like you who trys to sell his product by lying about it and bashing others.
you claimed your selling a CUSTOM built HAND WOUND 280 when its really a machine wound mass produced motor tuned by you.
again these are YOUR words NOT mine.
