RCU Forums - View Single Post - extending the batt wires
Old 07-02-2003 | 05:51 PM
00hex
Default extending the batt wires
There's a HUGE difference between a speed 400 and a speed 280. (A speed 300 draws about 2x the current of a 280, a 400 even more) If you're using the same battery the motor won't be able to draw enough current and won't give much power. If you use the proper size battery the plane will be very heavy.
