RE: Why???
Do you have a elevator to rudder mix put in. If you do, I assume the values for each direction are the same. The Sukhoi pitches harder one way vs. the other. You have to have two different amounts of elevator for each direction of the rudder. If you dont have a mix then I dont know what is causeing it. Mine pitches to the belly both directions.
