RE: Flaps on ultra stick 40?
Tec try using a mix. I believe the radio is capeable. Use the aileron channel as the master. And Channel 6 as the slave. That should do what you need. You may have to reverse one of the servo's. You do not need a Y harness. Look in the instructions under mixes and it should tell you how to program them.
Mark Shuman
