RE: World Models Velox
Yup, it doesn't take much to do the reinforcement. You might want to also take a second look at how the pull out wing is fastened to the fuse.. with only a PIN holding the rear part of the wing to the fuse.. I was thinking of embedding a blind nut into the wing spar and run a bolt through the fuse for a more secure wing mounting.
