RCU Forums - View Single Post - Does your DA50 do this?
Old 05-31-2004 | 02:25 PM
  #170
Antique's Avatar
Antique
Default RE: Does your DA50 do this?
Walbro carbs come from the factory with a grey coating on the end of the inlet needle, to keep the needle from sticking in the hole...Sometimes the coating doesn't work, but once the needle is unstuck it won't happen again...[8D]
It can take 15 or more lbs pressure to unseat the needle even when it's not stuck..You can take the top off the carb and gently push the lever down to get the needle to open....Don't bend it.....
