RCU Forums - View Single Post - Retracts...
Thread: Retracts...
Old 05-31-2004 | 04:33 PM
Campy's Avatar
Campy
Default RE: Retracts...
ORIGINAL: a65l
I'm building a Sportsman Aviation FW-190 ARF. Assembling. Kit includes mechanical retracts, first time I've ever dealt with them. They come unbent, you fit them, then figure out where your wheel goes, then bend them to form an axle. Right? I got one perfect, the other one was about 1/8" too short. I didn't want to have to re-shape the wheel well, so I tried to unbend it and re-bend it. I succeeded, once. It bent in the same place and when I was unbending it, it broke. So..... as i see it I have a couple of options.
1. Build with fixed gear. Not happening.
2. Probablly wouldn't work, but try to braze the broke piece back to the retract at a 90 degree angle to make an axle.
3. Buy a new set of retracts and start over. But then I wind up with my original problem, I have to bend them.
Is there a product that forms an axle? I.E., a sleeve that fits over the retract with the axle already incorporated? The box picture dosen't show the axle bent, there seems to be a sort of collar looking thing over the bottom of the retract.
Thanks in advance
Andy
Your best bet (and cheapest) is get another set of struts in the correct diameter for your retracts, and a set of "Dubro EZ Adjust" axles. Cut the struts, file a flat spot and install the Dubro axles. Make sure you use some locktite on the set screw(s).
FWIW - I leave the struts about 1/4" - 3/8" longer than I need. Then after I get everything lined up/set up, I trim most of the excess with a dremel.
