RE: What do you have your conversion in???
I would keep the air flowing fairly fast over the Funtana,s wings most all the time. If you go to land make sure the speed is enough. If you have to go around...do not punch the throttle to hard at one or it may tourque into the ground. Because of not much wing area verses torqe of engine!!!! Try testing that stuff at high altitude. Good luck....Capt,n
