RE: Razor 3D ARF
You don't need to worry about the "small" ailerons. They will look at lot bigger when you get into a high rate roll[:-]. Keep in mind this was designed as a dual-use aircraft between Pattern and 3D. It does both relatively well. Just wish this plane was built by a company with a little better QC.
