RE: Engine shuts off inflight please help!!
Sounds to me like it's going lean on you. Have some one hold the plane vertical and adjust for a good run at high throttle in that position. This will give you a slightly rich setting when level. If all is well with the tank pick up and the lines, and nothing has come loose on the engine (all this should be checked as you have) it should run fine.
