RE: Engine shuts off inflight please help!!
The LA 40 has what I think is called an air bleed carb. What I mean is there is no low end adjusting screw, just a small air hole. My first trainer had this on it & the hole had a little trash in it causing the same problem. I cleaned everything out good & the problem went away. May not be your fix but its worth a shot. I know how frustrating that can be.
