RCU Forums - View Single Post - Laser 3D
Thread: Laser 3D
Old 06-23-2003 | 09:57 PM
southern_touch99
Default Laser 3D
Well,
My new customized (& slightly modified) laser 3D is done. The airplane took two SOLID weeks of building night after night and a whole lot of laying in bed thinking of how to reduce weight on an airplane that is already suppose to be a little above 5lbs. I weighed the jewel after completion (without the cowl ->still painting) and the airplane came out to be 4 1/4 lbs. I have had 6 flights on it already and have another scheduled for tommarrow. The Saito .72 provides excessive power for the airplane. I have only gotten the hovers down to five feet off the deck so far, but when the new wears off Im sure tail touches will be no problem. As soon as I get the cowl on the plane I plan to take a few pictures and post them on here for everyone to look at. If you are intrested in building one of these planes then tower sells the kit for around $120 (yeah thats a lot) but you wont be disappointed [img]i/expressions/face-icon-small-happy.gif[/img].
Current Stats for Laser 3D
Motor: Saito .72 (running on 15% morgan fuel, slinging a master airscrew 13-6 prop)
Weight w/o cowl: 4 1/4 lbs.
Servos used: Elevator (2)Hitech 605BB, Rudder (1)Hitech 645MG-pull pull system, Ailerons (2) Hitech 605BB, Throttle (1) Hitech 425BB
Radio Used: Hitech Eclipse 7
Degrees of deflection on elevator: Up elevator 60 degrees, down elevator 45 degrees ( I want more but until further modification its impossible due to the control arms hitting each other).
Color: Ultracote Transparent Red, Transparent Yellow, trimmed in black.
