RE: Engine shuts off inflight please help!!
Also keep in mind that you're going through break in. I assume it is new. Things are going to change a little. You don't want to adjust for maximum rpm on the ground because in flight, it will lean out a little on you. Adjust to maximum and then back off 300 rpm's or so. Things like humidity and temperature will affect your settings as well.
