RCU Forums - View Single Post - GSP 65" Extra
Old 06-02-2004 | 05:01 AM
  #38
PeterLange
Default RE: GSP 65" Extra
Hi guys,
Sorry for the late answer. I have had only a very short first flight on Saturday afternoon. About 15 sec. after lift off (in the first turn) I've got a very strange flame out[&o].
And this with an unknown plane that I have to land with the "wind in the rear" and almost no altitude[X(]. OK, it was a hard landing and the prop was broken (on a Saturday afternoon[:@]).
A little bit off topic but I will tell the story:
Coming to the field I double checked (almost) everything, fired upp the engine for the first time (bought on a swap market) and after a very little adjustment it works very fine.
After a couple of minutes of "test driving" I made a lift off (straight and fine) and a left turn (also fine). Then I recognized that the engine has no power anymore. Understand me, I heard it running
but no reaction on the trottle and no power for anything. So after a few seconds confusion I decided to handle this as a dead stick[>:]. Hard landing with a broken prop,
some scratch on the cowl and the landing gear was off (no damage, I use nylon bults and didn't mounted the pants).
What has happened? The "after crash" check showed it -> no glow plug int the engine! The only thing I didn't check, it was not screwed in correctly and the engine fired out the plug after a few seconds in the air!
BTW I balanced on 120mm from the leading edge, it seems to be a little nose heavy but looked fine?! no it doesn't snap even when I was to slow. Only falling over the nose (2 meters over ground).
Hopefully next weekend!
//Peter
