RE: My DA-50 does it too!!!!
BG,
I'm using a 23-10 Mejlik at 1700 idle. So you left it with a little bobble when you lift the tail? It also seems like the idle is allot lower in the air now. Exiting spins I can almost count the revolutions the prop is turning, If I bump up the idle then it won't sit still on the ground.
RickP
