ORIGINAL: rfw1953
hilleyja - I saw your comments about the Fuji 50 BTSA. Whats going on with the engine? I recently saw that Fuji is now coming out with electronic ignition. This should help them a lot. It will certainly take away some weight and make them easier to start, but will probably take away some of the running smoothness as well.
This is really my first gas engine so I'm learning. The last time I tried to work this, it took me a while but I eventually got the engine to run. Idle was smooth and transition was pretty good. There was a bit of roughness with transition right out of the gate so I killed the engine and made a slight adjustment to the high-speed needle. I couldn't, to save my life, get that engine to start again. I even backed off the adjustment but was still unable to fire her up. I'm running with the Fuji spring starter so I should be getting pretty good engine startup spark from the magneto.
The exhaust is very black and very wet. The engine is farely new though I did acquire it used. I'm treating it as if it was new and running 25:1 oil with premium gasoline. I'm assuming I flooded her big time and fowled the plug. She is mounted inverted so I'm assuming I could not refire because of the fowled plug. Unfortunately, because of the the way I installed the exhaust deflector, removing the cowl is not easy and I did not provide a hole for access to the plug. I will have to cut the deflector flush with the bottom of the cowl -- just haven't done it yet. My local gas engine guru also wants access to the carb while the engine is running. I don't know how that will help him because the carb adjustments face forward -- doesn't leave much safe room for a screwdriver while running.
