RE: AFP won't run.
On my system, I had to install things in a certain order. I originally installed the program and patch, and all worked fine. I then installed the expansion pack and got the exact same symptoms you have. So, I reinstalled the patch and it all worked fine again. So, make sure you install the patch AFTER the expansion pack.
