RE: LT-40 wing joining question
Does anyone have a few good pictures of where to epoxy? Perhaps of an epoxied wing?
I think I am going to set the wings up at 3.75" like recommended and use a piece of scrap balsa to fit in the gaps. With enough diligence, I can probably sand the balsa sheet into a little wedge and wedge it up in the gap and epoxy everything together. It'd probably work well that way.
This is my first kit and I got into it wanting to have a "perfect" plane in the end. But I knew that since this was my first, there'd be bumps along the way. There are little tips and tricks that I've picked up along the way that the instruction manual doesn't even alude to. This airplane will turn out fine! But my next one will be that much better. I guess that's whats the hobby is all about.
Thanks for those replies and for any others that might respond.
