RE: Need help with tapering solid piece's of balsa
Wow Paul, that's exactly how I do it.
Blackie, if your control surface is wider on one end, then you might want want to do it both sides, otherwise, technically, the shape you wind up with won't be symmetrical. So, on one side, taper to half the thickness, then flip over and taper to final thickness.
