RE: PoleCat
Mine fits ok (I melted it slightly with a heat gun). I was worried about the tight fitting tank resting on the blind nuts, so I glued some 1/8" foam just over the ply inside.
It seems ok. I had a Hitec 85 on the cutoff, but since I was under weight, I swapped it out for a 225. Should put me just a hair under.
