Hello,
I have an ST 2000 that had set for quite some time. So I striped it and cleaned it. I used the same quailty carb cleaner that ive always used on many diffrent engines. It cleaned up nicely as well as the carb did. So it has good compression i started out with the basic (high and Low speed)needle setings. And a new Fox long glow plug and good quailty 5% fuel, Well no go I cant get it to run for the life of me Ill get a slight spit or sputter every once in a while but no hope I got so tire of smacking the prop i built a high torq starter fot it so i could turn some RPM and play with the needle settings while spining it over still no luck im stuck, Can you offer any suggestions?
Thank you
[email protected]
