It sounds like the carb's just not set up correctly. It's easy to miss the settings. See the note we posted earlier about getting the SuperTigre carbs set up. The instructions apply to all SuperTigre carbs.
Another problem with the large SuperTigre engines is the fact that it's easy to get them flooded while trying to start them. I tend to flood them if I've not run one in a while. Choke carefully. You can usually tell the engine's flooded when it will on "pop" occasionally, and will tend to run backwards when propped.
In many cases, we use our safety stick and prop the engine backwards to get it to start running. Once it's running, we then get the engine leaned to proper RPM.
We usually use an O.S. #8 plug and 5%-10% fuel. The engines like lower Nitro fuels better than the higher-nitro stuff. Oil can be as low as 10%-12% on a well-broken-in engine. If the engine's not broken in, then use fuel with at least 15% oil.
We hope you find this information helpful. Should you have any further questions or concerns, please do not hesitate to contact us at this email address. (Please be sure to copy all previous emails into any future questions.)
DID YOU KNOW that our web pages now all contain FAQs? (Frequently asked questions) Please drop by and take a look! We hope you'll find the information helpful and valuable to you.
Sincerely,
Bill Baxter, Manager
Hobby Services
1610 Interstate Dr.
Champaign, IL 61822
USA
Phone: 217 398-0007
Fax: 217 398-7721
Email:
[email protected]
Web:
http://www.bestrc.com
