RCU Forums - View Single Post - Problem with Eagle 2 horizontal stab
Old 06-03-2004 | 02:33 PM
Connery's Avatar
Connery
Default Problem with Eagle 2 horizontal stab
I finished building an older Eagle 2 kit and discovered a problem with the horitzontal stab. During assembly, I made sure that everything was aligned properly but now the stab is a little off. The actual surface of the horiz. stab is at 0 degrees in relationship to the wing (as per the plans), but now the left tip (looking from the rear) is 1/8" low and the right tip is 1/8" high. Do you think it will still fly correctly?
