RCU Forums - View Single Post - need help picking out the best first plane
Old 06-03-2004 | 04:14 PM
rcravincase
Default RE: need help picking out the best first plane
oh, i forgot to add. it has a mode change flight control software for beginners, it prevents over correction, couples the elevator and rudder control, and the pitch control is lowered to allow you to get used to it. im not sure what all that means, but it sounds as though it helps make your first flights much easier. and if i were to crash, about the only thing it is going to hit is soft hay from our farm fields.
