RE: about to throw it all out the trash :)
What do you mean didnt set a Curve %?
Do you mean pitch and throttle curve?
Right now its
P1 0%
P2 25%
P3 50%
P4 75%
P5 100%
This is the same for pitch and throttle. Im using a 7C Radio. Do I need less pitch more throttle or vica versa?
Isnt it better to learn without HH mode first? Also if your not in HH mode is it normal that your always trying to keep the tail straight?
I also noticed when I hit the rudder in a certain direction the tail will go crazy and keep going that way. What causes that?
The GY401 when its a constant red signal that means it is HH mode correct?
