RCU Forums - View Single Post - YS 61 FR - sensitive/worn needle
Old 06-04-2004 | 01:37 PM
kcnelson
Default RE: YS 61 FR - sensitive/worn needle
Thanks, Dave.
It's been a long time since I set up a pipe. Is the right approach to adjust the length to get the peak RPM? How much change should be expected between the "wrong" length and the "right" length? If the pipe is too short would I expect sensitivity problems? Is 10K with a 12x10 APC and 15% fuel at sea level with dry air (Silicon Valley) about what I should expect?
