RCU Forums - View Single Post - Trouble With Midrange on Fox 3.2
Old 06-04-2004 | 09:16 PM
BAS
My Feedback: (28)
Default Trouble With Midrange on Fox 3.2
I am still having a minor issue with the midrange on my new Fox 3.2. Using Amsoil Series 2000 at 50/1 , 22/8 NX prop. Sycrospark ign , not throtttle coupled like my Brison 3.2. I have tried everything from leaning the low end to where transition is lean to riching it out to where burble is worst. The problem is right around the 5000 rpm point , transition is 4,800 rpms from low to high on transition. The motor just will not smooth out until rpms are increased to around 5500 and then it is fine on up to full throttle. High end is about 7/8 out , low end all the way from 2 turns out to in to various settings of around 1 and 1/2 , ect ect ect. My Brison with the throttle coupled ign just does not have this problem i havent tounched the low or high end from out of the box. Any help would be appreciated??
