RE: questions about differnet Models of Toger Moth
The gws slow flyer tm is a great plane .the only problem is you can't fly it in anything over a 10 mph wind.If you get one,get yourself some li-poly batteries in the 7oo mah range.these will allow about 30 min. flight times.It is a very easy plane to fly.There are also a bunch of hopups over 0n the e-zone website,search under "a tigermoth story".If you break a wing or damage the fuse ,it is easy to fix with some 5 min epoxy as well.
