RCU Forums - View Single Post - Opening nitro engine
Old 06-05-2004 | 07:11 AM
R/C Madman's Avatar
R/C Madman
Default RE: Opening nitro engine
The number one thing to do before taking you engine apart is to clean it very very well! Have a clean surface to work on and then start the disassembly. To see if it still has compression all you need to do turn the flywheel. If you ever did that when it was new you will know the difference. There should be a tight spot that is hard to turn with your fingers.
