RE: fail safe??
Yes check the failsafes after every flight. I fly in a very dirty RF environment, and a good setup here should get 0 failsafes.
Also check the max pump voltage after every flight. That one helps spot impending clogged fuel filters. The max voltage will stay pretty stable from flight to flight then start going up maybe .05v after each flight. Then it is time to clean the filter.
