Tower Trainer 60
Happy to see that you are going to rebuild the wing on your TH .60. This means that you are at least partially into the building stage, the ultimate modeling experience. Southerntouch has a very good suggestion about the TH Uproars, both 40 & 60 size. A .40 size kit costs 40 bucks, the .60 size 60 bucks. Both can be 3D aircraft or gentle as a lamb. One of our pilots learned to fly on a 40 Uproar fitted with an OS 46FX. He now has many other aircraft but always keeps an Uproar around for fun flying. When you advance to the aerobatic stage you can increase the control surfaces by a few sq.inches, dial up the throws and it will do all you ask of it and maybe a few things you didn't know you could do. They are build it yourself kits but that shouldn't be a problem for you if you can rebuild the TH .60 trainer wing. Hang in there. Most of us started in the limited income stage too. In my case it was mowing lawns and selling newspapers in the 30's. It gave me the incentive to keep up modeling for 70 years.
