RE: U Can Do 60
this post is huge! and i thank everyone for their input on the ucd 60. i put everybodys own thought about the plane and put it all together for mine! so far i'm running a saito 100 w/ cline reg. a 16*4w apc 15% wildcat fuel, xp8103 with hitec 605's on the ailerons, 537's on the elev. and a hitec high speed high torque on the rud. w a hitec hs55 on the throttle! fuel tank located near the cg which is balanced a 6 1/4" form the LE.
next upgrades will be digital servos! i wonder if the ds811 will work?strong enough?
and the rudder mod. just waiting to see how others turn out!
also tuning my saito with the cline reg. seems not right! i cant get the high speed neddle to richen, theirs no leaks in the fuel system. its not running lean-exhuast oil seems normal, not burnt! any input on this? thanks rod!
