Looking for a pattern plane for 1.20 2 stroke engine and pipe.
poorbs
You wouldn't happen to have a set of plans for the Boxer 60 you would like to sell? I have been wanting a copy, but they are not available anymore.
As for the 120 sized airplane, if you are into scratch building, the Gator Typhoon 2000 is all wood, and can be powered with a 120 2 stroke.
I'm finishing up a Fivol II which is an early 90's design pattern plane with a one piece wing, and designed for a 120 4 stroke. I'm putting a Bully 120 2 stroke in it, and had to make extensive modifications to get the pipe to fit. It was not easy, but do-able.
Greg
