RCU Forums - View Single Post - Nextstar engine alignment
Old 06-07-2004 | 11:01 AM
Bax
Default RE: Nextstar engine alignment
Right thrust is used in a LOT of models to compensate for the fact that the airflow from the prop twists around the fuselage and pulls the model to the left. This is done on real aircraft, too.
Just ignore the offset and fly the model as designed. You'll be fine.
