RCU Forums - View Single Post - Biplanes for Pattern
Old 06-07-2004 | 09:56 PM
Jeff-RCU
Default RE: Biplanes for Pattern
I turned a Dr. Jekyl into a biplane last year with limited success. There's pictures of it on a thread around here somewhere. The rudder coupling seemed to vary with speed, so if you mixed out the coupling at mid throttle, it would pull to the canopy during stall turns. And then when you were foolling around at higher speed, or if you happened to enter a manuever at a higher speed that usual, the plane would do things wou wouldn't expect. I'm sure Chip's double vision does a lot better job, but I found it frustrating to fly a biplane in competition.
