RE: seeking some 4-stroke engine advice
OK, I understand now. I was told once that i should take a pin, put it in that hole and run the screw down to that pin, then remove the pin. this is where the engine should be. i think at the moment that opening may be slightly larger but it seems to be ok. How will the pump affect this opening? I am running a Perry Oscillating pump not a Perry Regulating pump. I am not using muffler pressure.
