RE: Tapered-Bore Engine Break-in - Upgraded
Dar,
If anything you got it backwards, there is no effective heat treatment for cast iron and still till temps reach 600 degrees or so. For aluminum and brass it is lower. As discussed on other threads no one can prove that cast iron heat and steel heat cycles at our engine's operating temperatures. Despite the voracity of some peoples statements.
