ORIGINAL: Mark.v.
I have a question that needs answering about the engine mounts if someone can help. I don't like the idea of tapping the threads, i don't believe it will hold tight enough, is there a problem going right through the stock engine mounts and using bolts with nuts? I would much prefer this way, and would feel safer with my setup.
You can drill all the way thur just use a nyloc nut...thats all
