RCU Forums - View Single Post - Is Ignition Battery getting low when....
Old 07-08-2002 | 07:47 PM
Geistware
My Feedback: (16)
Default Is Ignition Battery getting low when....
Add a hobbico volt watch to the circuit. That way you can monitor the battery with and without load. On my Brison with C&H Ignition, the load seems higher when I first start the engine and after is has run and warmed up, it is lower. (voltage higher)
