RE: NEED HELP WITH FLAPS
If you put each aileron servo on seperate leads to the Rx you should achieve the desired result. Also make sure yout Tx is setup for flap operation. Ex. on the Futaba 6EXA, you have to set FP on the W.MIX mode. Yours may differ, check your manual for info. Good Luck. [8D]
