RCU Forums - View Single Post - Tapered-Bore Engine Break-in - Upgraded
Old 06-09-2004 | 10:02 AM
DarZeelon's Avatar
DarZeelon
Default RE: Tapered-Bore Engine Break-in - Upgraded
Brian,
It is an assumption.
The assumption results from comparing the fit of Jett engines to most others.
I suppose it is to break the extremely tight TDC bind, because 1 whole minute is not needed to get the bottom end wet enough with oil; this takes only a second, or two at most.
Then why don't we ask Dub, or Bob27, his representative in RCU, about the purpose of the full 1 minute rich run?
