RE: Flush Head rivets, how do u do them?
The easiest way I have found is the rotating method, but use a Dremel varible speed moto tool to put the sharpened brass tube in. The Dremel is set up to take a 1/8" shank but by using sizes that fit together you can go up or down in diameter from there.
