3D Control Throw Recommendations ??
Hi,
Ok i posted a while back about my Wild Card 3D, its nearly finished i just need to set up the control throws............ the instructions only give an Initial Recommedation of the below
Elevator 25mm up and 25mm down
Rudder 50mm left and 50mm right
Aileron 20mm up and 20mm down
It then states once comfortable with the plane these throws can be increased Significantly ??? i wanted to set it up on my 9C with Dual rates soo could someone give me an idea of what control throws would be good for high rate for ulitmate 3D performance and i will use these initial rates above for low rate..........
Thx for any help, info
