RCU Forums - View Single Post - ARF wing or stab failures
Old 06-09-2004 | 06:57 PM
8178's Avatar
8178
My Feedback: (17)
Default ARF wing or stab failures
I’m astounded with the number of post in the ARF forum about wing or stab failures. It looks like it would behoove all of us that want/have an ARF or two in our air force to check the wing carefully during assembly and before every flight. Although the wings are usually pre covered it would be smart to dig around in the wing roots some before assembly to make sure you understand the structure. Check the wing bolt mounts in the fuse and the wing structure around them. Check the bolts, are they strong enough? If the wing is a tube mount, how strong is it.
I’ve also heard of ARF firewalls pulling out of airframes with the engine running, not fun if you are in front of it. No wonder there seem to be so many crashes now-a-days. If you have only assembled ARFs find an experienced builder to look over the structure for you? There a lot of G forces at work with these little aircraft.
