Engine Adjustment Question
If you are running the engine inside a cowl you might also want to try venting the carb diaphragm inside the fuselage. How this diaphragm moves has an effect on mixture and cowl pressure may be screwing it up. The diaphragm now vents through a small hole in its cover, its not hard to install a nipple and a hose, might be worth a try.
