RCU Forums - View Single Post - Four Stroke?
Thread: Four Stroke?
Old 06-10-2004 | 12:13 AM
  #33
DarZeelon's Avatar
DarZeelon
Default RE: Four Stroke?
Gary,
For some reason you mentioned the 'bogus' ABC nickel composite, yet forgot about the original, true ABC, thus not completing the answer Matt was seeking.
True ABC is a low expansion, high silicon (hyper-eutectic) Aluminium piston, running inside a Brass sleeve, that has been electro-plated with Chromium on its inner, running surface.
This sleeve can either have a tapered-bore and a ring-less piston, or a parallel bore and a ringed piston, mostly in four-stroke engines.
The ring could be either conventional, or Dyke's type.
The true ABC started it all.
