RE: Hanger 9 alpha trainer
You can convert the engine to two blade by removing the back thrust plate and using a stock size. This lets you use a Dubro spinner a a APC 10x7. You also must re-tune both the low and high needles. If you need 3 blade props check my web site. Dadstoysbg.com. Dennis
