RCU Forums - View Single Post - 34cc Poulan
Thread: 34cc Poulan
Old 06-10-2004 | 07:48 PM
av8tor1977's Avatar
av8tor1977
Default RE: 34cc Poulan
It seems to me that at one point someone said the smaller Poulans like yours had the magneto mounting points for the coil cast on the engine housing. The larger ones have the coil mounted on the plastic saw part, so you either have to cobble up some kind of a mounting, or use electronic ignition which is what I do. The 42 & 46cc Poulans make great conversions. Pull your side cover off, and see how the coil mounts to be sure. It should make a good conversion.
Good luck,
Av8tor
