RCU Forums - View Single Post - Engine mounts
Thread: Engine mounts
Old 07-01-2003 | 02:14 PM
3 Channel Brain
Default Engine mounts
A good way to beam mount an engine to put the beams out against the fuse sides then get a piece of
1/8" plywood or circuit board - bolt it down to the beams after cutting a "U" in it & bolting the engine to the sheet. This is replaceable/ repairable in case of excess ground effects.
