newbie with a question
You should have your radio set up so that with the throttle stick clear down and the trim down the throttle should be closed on the carburetor. When you are ready to shut down lower the stick and pull the trim all the way down and it should quit.
An option is to block the exhaust or pinch the fuel line closed at idle. Not recommended but it works.
